Hi Guest!
I remember you mentioning you grew up with those beasts flying overhead. When I was a kid I build a model B-36 and it was always my favorite airplane but never have seen one in the flesh let alone flying.I grew up in Fort Worth, and those a/c flew overhead almost every day. You felt them before you heard or saw them.
The 36 is big, but the 29 is no slouch either. Paul - check out the 9-foot diameter tires on the early Peacemakers -
Some history here:
Goleta Air and Space Museum: Convair B-36 Variants
www.air-and-space.com
Holy cow! 28 cylinders! I had no idea they were that big."With a fuel load of 33,626 gallons of aviation gas and 1,500 gallons of engine oil, the B-36 Peacemaker required a fleet of tanker trucks for each fill-up. At cruising speed the B modelโs six Pratt & Whitney Wasp Major R-4360 engines consumed 600 gallons of gas an hour. Each 28 cylinder engine had its own 250 gallon engine oil tank. Each cylinder had two spark spark plugs for a total of 336 per plane."
Increadible.Basil - *this* is 28 cylinders of power. The P&W R-4360 radial:
Cranking and spinning:
amazing that an aircraft that size would have a single main wheel! (I know they changed it laterโฆ)
pimaair.org
