AweMan
I have a couple of Harbor freight items also, One is a 1/2 In. drill press {Bench Model} and the other is a bench grinder. The Bench Grinder did "Burn up" {maby my fault maby not}. The drill press is fine for small items, but if you try to use a 1/2 In. drill bit with it, it will deffinately "Slip the belt", It still works with the 1/2 In. bit, you just have to go real slow.
What sold me on Craftsman:
Years ago I worked in an auto salvage yard, while working there I found a 1/2 In. breaker bar, it had a handle about 18 inches long {I loved it}, it would break most bolts either loose or twist them off.
One day I was useing it to remove the king pins from an old ford truck. Some of the bolts were 3/4 and rusted solid, so I got a cheater pipe and commenced to twist on these rusted bolts. You guessed it, the breaker bar snapped off right at the head. I took it to sears and as you might guess they were amased to see that ancient breaker bar. They promptly gave me a new one although they no longer carried the 18 In. model they gave me the longest one they had NO questions asked.
I also have an array of Snap on hand tools as well. Good quality. Although I find the edges on thier end wrenches a little hard on my hands. Getting the broken ones replaced means tracking down one of those trucks which isn`t easy in my area.
Kerry
Kerry
Hi Guest!
