New tie rod ends came today -- perfect timing. Reassembly was a snap. These particular TREs appear to be self-sealing as there was no grease zerk hole on the bottom. Two less zerks to worry about? I'm good with that. Before I took the TRE off, I measured the length of the exposed threads with a caliper and then locked the caliper. I think I was able to pretty accurately get the TRE back into the exact same spot that it started with. Finished up the left side by hitting the three zerks with the grease gun, cleaned everything up and put the tire back on. Now, it's off to the right side of the car.
Hi Guest!
