PAUL161 said:
What does <span style="font-weight: bold">SWM</span> mean?
Single Wire Multiswitch.
An SWM "box" allows you to ditch the 2nd coax and use a single coax throughout your house. When they came out a lot of people were designing their systems so the SWM box fed a splitter, sometimes in the garage or a utility room if it was near the wall where the dish was...that way all the boxes and power supply were hidden away and the rest of the house worked like it was on a simple cable-TV system.
You'll also hear "LNB" - it means 'low noise block' but when you hear the term just assume it's the part of the dish that receives the signals (it's the antenna parts that hang in front of the dish).
Slimline is the popular style dish direct-TV started using that is a horizontal oval with a wide LNB for HDTV service. Other dishes were round, vertical oval, or somewhat square with rounded corners.
SWMLine is a Slimline dish with an LNB that is also an SWM (whew, got <span style="font-style: italic">all</span> those terms in one sentence
), therefore eliminating the SWM box and making the entire satellite system a one-coax system just like cable...sort of. You still need a splitter to make it work, but the wiring is a lot cleaner.
DVR is digital video recorder (Tivo is a brand-name of a DVR).
HR20/21/22, etc, are model numbers of the dTV receivers. If you get HD service with dTV you're likely to be supplied with an HR21 or HR22 receiver.
Uh... on the forums you'll see dTV, dT, and d* - all shorthand for direct-TV.
Whew.
