Keith_M
Hi Tom,
This is really getting to be quite the puzzle. If you have spark and gas, it should at least try to start. The fact that it ran not too long ago (albeit roughly) means to me that there's not something seriously wrong. At one point you said it tried to run when fully choked. Maybe the mixture is just not rich enough to start at the cold temperatures that you're having? My Healey will not even try to start if the temperature is below freezing. I can usually get it to fire a few times if I hold my hands over the carbs to richen up the mixture, but the choke by itself just doesn't make the mixture rich enough. Is your garage warm?
Have you tried removing a plug and holding it to the block to see if will spark to the block? That's the best test that I know of for spark. Be sure to hold the plug with insulated pliers and keep it away from any gas that may be around! You should see a nice blue spark.
In my experience, if the battery can turn the starter motor it will have enough juice to spark the plugs, so I don't think it's your battery.
Keith
Keith
Hi Guest!
