Sanity check please.
Vespa
I need to check something here. With the 100-4, there are the BN1 front fenders, and the BN2 front fenders. The easiest (only?) way to tell them apart is to measure the distance from the top of the wheel opening to the top of the fender. Here is the Austin Healey service note about it.
https://www.acmefluid.com.au/larry/a421.jpg
It notes that the measured distance for the BN1 is 9 1/2 inches, and 9 inches for the BN2. I would SWEAR it was 11 inches for the BN1 and 9 inches for the BN2. I just seem to have this strongly in my memory. Am I wrong? I would assume that the Healey service note is correct, but, dang! :smile:
- Paul B.
Healey 100
I measured my BN1 and it came out 9", give or take a quarter inch or so. Don't have a BN2 to check, but my car has been parked next to BN2's before and the higher opening of the wheel arch is pretty obvious when you see it.
My fenders have plenty of body work done of them over the years too, no telling how exactly they match the original fender dimensions.
V
Vespa
Hmm, mine are 9" also. I think the Moment/Anderson book is correct when they say it's 9" for BN1, 7.5" for BN2. Thank you Bill for measuring your fenders!
- Paul B.
NutmegCT Sanity check please! Other Cars 90
RickB SANITY CHECK PLEASE - 1-3-4-2 ??? MG 17
Rut Sanity check! Spridgets 2
M Sanity check - starting project on MGA Restoration & Tools 6
sparkydave Sanity check Spridgets 3
RAC68 Corona Virus Sanity Austin Healey 25
regularman A plan to keep my sanity Spridgets 6
mjobrien Start up Sanity check….. Austin Healey 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
