sandblast and primer question
tri_carb_healey
so theres a bit of surface rust under the healey. and some real rust in the usual spots. my question, is it a good idea to buy myself a sandblaster and blast away the surface rust and put some primer down under the chassis and floor pans, outriggers etc. what primer should i use? this car has been in the family for forty years so i'm not looking for a concourse resto just something to keep her protected till i can down a frame off resto. any suggestions, ideas, warnings.
i plan on using my miata to practice the sandblast technique (if there is one). help me out experienced healey owners. most healeys on here are amazing!!!
This can be one messy job:
.However, if you have the space and protective gear to use the sand blaster in then go for it.
ONTOH,:
a spot blaster may allow you to do what you need and is not so messy.
what primer should i use?POR-!%
---------------------------------------FWIW--Keoke
Surface rust can be sanded off or chemically treated and then primed. Rust through needs to be replaced with patch panels. I would think a sand blaster would be very messy and unnecessary for chassis parts. I have minimal chassis/frame surface rust and it hasn't changed in 30 years.
I have never felt compelled to clean up the underside of my car. A lot of it is covered with oil from the transmission leaks which provide adequate rust proofing.
I do not have a lot of experience with them but there are a lot of them that dissolve or encapsulate surface rust and turn it black. Check out auto repair/parts shops
I agree about sandblasting being messy...more appropriate for rust removal on individual components than working insitu. BTW, primer may not be your best option for rust prevention.
I've just sandblasted a BN2 down to bare metal. I don't think sandblasting is feasible unless you have disassembled the car. I think the 'rust encapsulater' paints work OK, and should do in the short-medium term.
Consider using a paint stripper first if you have a couple layers of paint.
We blasted the whole car with a couple of these (wore the first one out):
https://www.harborfreight.com/110-lb-pressurized-abrasive-blaster-95014.html
You need a pretty big compressor, 5HP/30gal at least. You'll get about 5min of blasting before you have to refill the blaster (we split a 100lb bag of sand into two loads). We used #30 grain Monterrey sand; should be available at your local big box hardware store. I think we've probably used 30-40 bags of sand (so far). We now have a beach on the side of our shop. This is a nasty job; wear eye and lung protection (silicosis is bad news). Wear coveralls and tape up the sleeves and pantlegs to prevent getting sand in some irritation-prone skin areas. Get spare nozzles. Keep your sand dry else it clogs the blaster (I wouldn't do it on a really humid day, for a couple of reasons). Get a rock or piece of bag in the blaster and plan on wasting 10-20mins dumping all the sand out to find it. It's a nasty job, but when everything's working right--happens occasionally--it's actually rewarding.
After blasting, use a good catalyzed primer. I don't think an etching primer is necessary--a blasted surface is perfect for paint. The 'high build' primers do just that (they're almost like thin body filler). Use a 'metal prep' chemical before painting--they are available for aluminum and steel.
I'd get to know your local auto paint guy--if he's experienced he can help you out a lot.
This took about two (2) days to accomplish. However much was blasted in a day, the same area was primed with DP40/401 before the end of the same day.
thanks guys so many great ideas and tips!! i dont know what my best route is yet but i will look at the eastwood line as a temp fix for a few years!! i love you guys
Scrape, sand, prime and paint....do not use undercoating!
Patrick
And definitely do not sand blast without a complete strip down, I tried it on the back end of the chassis and gave up after several seconds - sand every where, especially on the diff - could have ended up with sand in the bearings.
