Since it is off the car, I figured I would change the oil seals, check the bearing, clean and paint the differential on my TR6.
I got the case open. I removed the inner shafts. I pulled the carrier bearing caps. All with surprising ease.
Then I came to the part about using the S101 tool. Is there any work arounds for not having this tool? Or should I just put everything back together, since it all looks like it is good to go?
Jack
Jack
Hi Guest!
