S-Type Squeakey Steering
shorn
My 2000 S-Type Jaq makes a squeaking sound when the steering wheel is turned a fair amount. No sound if the wheel is turned slightly. Power Steering fluid is full, OK. The sound actually seems to be coming from the steering column rather than the power steering mechanism, although I am not sure about that. Any ideas before I take it to the dealer???
John S Farrington
I would guess that it is your power steering (serpentine) belt that needs tensioning or replacement.
S
shorn
It is hard enough to even find the engine buried under all those plastic parts that sit on top, but the belt is even further down. Is it a difficult job to replace it or should I just leave it to the dealer?
John S Farrington
Replace it yourself: it builds character and makes your hands look like a real man!!
Platinum
...and here I thought you had an impaired sense of humor, John. /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/cheers.gif
Exotexs
funny how some things never change. My 1965 S type has a similar squeak which is caused by the top and bottom nylon
bushes rubbing against the inner steering column. I replaced the original bushes with the nylon version a year ago. The originals were made of fibers that looked like horse hair. I have sprayed Silicone Lubricant and the squeak dissapears for a few drives, then comes back. In my car, it is not the Belt or the Power Steering, it is the Inner Column bushes. It is also very peculiar that Jaguar decided to revive the name "S type" back in 1999, as opposed to reviving the name "MK-II", because of the two original cars, the MK-II is the most wanted, even though the S type of 1963-1968 is the better car of the two.
S
shorn
It does not appear that it is the belt that is causing the squeaking on my S-type. I will have to check out the bushings.
tonyh
hi, im from england on a smilar forum over here the squeaky steering col has been discussed a lot, the answer is that the bushes on the col dry out and that makes the squeak that you are getting, jaguar have a replacement set that will stop the sqeaking, have a word with your dealer he will be able to give you more detail, but you can buy them and change youself or get an independant to do it as it is not a big job
S
shorn
It turned out to be worn ball joints and lower control arms. There was a factory recall in the first eight months that I owned the car regarding nuts for the ball joints studs that were not properly torqued. I took mine in for the recall and the dealer retorqued the nuts. However, I had driven the car for 8 months prior to that recall. Appartently the ball joint stud elongated the hole in the control arm and caused excessive wear in the ball joint itself. A few years and 35K miles later, when the squeaking started, the car was, of course, out of warranty. Cost for the new ball joints and control arms, both sides, was $3200. Back and forth discussions between Jaquar (Ford) and myself finally led to a settlement where Ford paid for the suspension problem because the damage was most likely caused by the improperly torqued nuts on the ball joints.
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
