That looks like a how-to article that's just begging to be written!!
And if it's not begging, I am. PLEASE!! Tell us how you did it!
its a simple set up.
you need a plastic container big enough to fit what you need to de rust.
find four ferous metal rods or flat bar.
fix one in each corner
connect all four rods together with copper wire, make sure you have a good connection.
fill container with water and mix in some soda christals, make sure its sodium carbonate. bicarbonate does not work.
a good one is arm and hammer. you need enough to just make the water go cloudy.
hang watever it is you want to derust from a copper wire into the water,
connect positive from a battery charger to the outer rods
connect negative to the bit you are de rusting
turn the charger on, works best at around four amps. and sit back and watch it sizzle.
This works by line of site between the part and the rods, so turn the part now and again,
this will only remove rust, it will not attack the good metal, so it is safe to leave in for as long as it takes.
I have removed rust from all of my suspension components in a large tub this way,
