TR3driver
Great Pumpkin - R.I.P
IIRC, you said you had a points distributor installed. The original setup used resistor wire, running over to the starter solenoid, for the ballast resistance; plus a "drive resistor" that was only for the electronic ignition.
Are you saying that the resistor wire (pink with white tracer) is smoking? Or do you still have the drive resistor connected somehow? Although it looks rather like a discrete ballast resistor, the drive resistor is a higher resistance and has no use with points. If you are using it to pass power to the coil (or points), it may well be your problem.
Hi Guest!
