Svcmangler
Hey everyone, so I pulled the engine and did a reseal of all the oil gaskets. While apart I decided to replace the chain tensioner and gears. I lined up the gears so the the dots were a straigth line both at the 1 o’clock position. I have read that the manual says to line the dots up with each other in order to get TDC. Apparently this is incorrect as it put #4 at TDC not #1. I put the engine back in and started it up and it backfires and coughs etc. when I put the timing light on it the timing is way advanced so much so it is completely off the timing marks. I don’t understand what could be wrong. I took it all apart again, and everything look correct. Distributor is at 2 o’clock position and #1 is at TDC. What else could cause this?
