blkcorvair
It seems lately I am getting a bit of run on or pre ignition. It may have started when I threw the colder plugs in. Im thinking that colder plugs will transfer less heat thus raising combustion chamber temps? Or am I thinking backwards? My thoughts are I may have to go back to a BP6es instead of the 8es..... Running 10deg BTC maybe I should go a bit more.
Cars' also running hotter again. Was actually vapor locking the fuel pump at traffic lights. Tossed it went back to the facet pump and reset the press. to 2 lbs. Im running a bit leaner at idle which should be fine. I think that mech. pump was giving eratic pressure volumes cause Id go from one extreme to the next. Seems better now, but I may have my other radiator cleaned out and swing it in. It was 75 or so today and I was back up near 200-205 under stop and go...
