Rubber Bumpers
Bob Claffie
On the late model Midgets what is behind the front bumper ? Do they look ugly without a bumper or can you use an early chrome bumper ? Likewise same question about rear bumpers ? Getting antsy about finding another project but winter pickins are kinda slim. Spridgit would fit my needs but I am not a RB fan. Thanks, Bob C
JPSmit
I don't think they look horrible without a bumper but will need some adaptation.
Front has two beams coming out the front that the bumper mounts to. These come through where the grill used to be. If you cut and cap them, an original grill bolts right in.
The holes for the signal lights were cut bigger in the RB cars. The little "plinth" that the original signals attached to is gone. Some people push the old signal in from behind and it sort of fits. I had my body guy fill the holes in completely and drill for beehives.
Also under the bumper is a larger hole for air flow to the engine. I had it filled also.
Back - I can't recall how the bumpers are attached, but, the real problem is that they cut off the curved area under the tailights to make the rubber bumper fit. My car had been lightly rear ended so I had my body guy replace the RB valance with a chrome bumper valance, then everything worked for chrome bumpers.
not an easy conversion.
Bob Claffie
Bob Claffie
Thanks JP, I remember thread about a similar fix on MGB's but was fuzzy on the details. As you said not an easy or cheap fix but doable.
C Spitfire Rubber bumpers Triumph 3
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D MGB Painted rubber bumpers. How long will they hold up? MG 1
N MGB-GT Have you removed your car's rubber bumpers? MG 7
Bob Claffie MGB Painting rubber bumpers MG 4
PAUL161 Painted Rubber Bumpers! MG 10
L Advice for cleaning/painting 1980 rubber bumpers MG 8
fb_bf Removing the steel from your rubber bumpers MG 0
coldplugs YA, 2CV, Mk 7, and rubber bumpers all in 1 day Spotted 0
bigjones Polishing rubber bumpers Spridgets 20
S TR2/3/3A brake lines and rubber bumpers tr3 Triumph 12
T refurbish rubber bumpers? MG 3
B Removing the Ugly Rubber Bumpers Spridgets 6
Baz Rubber bumpers on my '70. MG 20
69MGC Reassembling the front and rear rubber bumpers MG 18
budk1953 Rubber bumpers Spridgets 4
MadRiver Source for rubber bumpers for seats? Triumph 3
jlaird Rubber bumpers MG 2
Nunyas Lowered Rubber bumpers and bump stops... MG 21
B Painting the bumpers on a rubber bumper car MG 8
M cleaning rubber bumpers Spridgets 2
NutmegCT MGB-GT rubber -> chrome bumpers? MG 16
B painting the rubber bumpers MG 9
7 are your rubber bumpers dull?? MG 11
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
L Red Rubber Brake Grease Austin Healey 2
C MGB Rubber Bumper cover removal MG 5
drooartz Replacing Bugeye windshield rubber Spridgets 6
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
D Top Door rubber and fuzzy seal Spridgets 5
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 Weather stripping and rubber parts Other British Cars 1
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
B TR4/4A Rubber wiper motor mounts Triumph 4
BoyRacer Rubber Fender Buffers Austin Healey 2
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
T How do you secure your door rubber trim? Austin Healey 9
W Spitfire Hard Top rubber Triumph 5
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
M Quarter light rubber replacement Austin Healey 6
Rut Windshield rubber seal Spridgets 6
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
I Best glue for rubber door panels? Spridgets 3
S TR2/3/3A vent lid rubber Triumph 11
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
