Re: rpm's
/ubbthreads/images/graemlins/savewave.gif Bill!
Since the SU carbs do not have temperature comphensation,when the engine reaches its full runing temperature [HOT] the Idle speed generally increases rather than decreasing.In my cars I set the Idle speed about 200 RPM low at a running temp around 160 Deg F,which requires that I run on choke for a short period to maintain a steady 800 RPM Idle. This has been my experience with all hot runing engines equipped with SU carbs. Consequently, you may want to have a look at your overall tuning and see if your car will respond accordingly-FWIW---Keoke /ubbthreads/images/graemlins/driving.gif
