Well my engine does run on when I turn off the key. What do I adjust to fix this?The books say idle rpm should be lower; but in general I'd call that low enough. The only problem with idling high is that the engine may show more of a tendency to "run on" after turning the key off.
One big caveat is that the old tachometers frequently read a bit high that close to 0, so if you do want to get it down lower, the first step is to double-check the tach reading.
Most LBC vendors (TRF, Moss, VB, BPNW, etc) offer the Bentley reprint of the factory workshop manual "The Complete Official Triumph TR2 & TR3 1952 - 1961". Or you can download a scan fromDo you have a service manual yet? If not, I would start by getting a copy of that,
What do you mean by break the connection? I must remove a line that connects them together like the throttle rod or mixture rod? (see the great picture above)Don't forget you must also break the connection between the carbs before adjusting, so you can get the idle where you want it and still ensure both carbs are drawing air equally at the new idle.
Thanks for all the help you have given you have given great help to a lot of my posts. I'm glad CJD mentioned the disconnect it's good to know as well for future issues.He means to loosen one of the clamps on the connecting shaft, #4. Ensuring that both carbs flow the same amount of air at idle is known as "balancing". The procedure is covered in Practical Hints (which is where the photo came from, I just massaged it a bit to make it easier to see).
