Rover engine that started as Buick?
Jerry
I am told that Buick sold the plans to Rover for one of their engines. Is it an exact copy? I am looking for a light weight engine and this has an aluminum block doesn't it
Jerry
Mickey Richaud
Yep - got one in my TR8.
Read all about it:
Rover V8
Mickey
LarryK
Deal was consumated in 1964 between Land Rover and Buick on an overseas flight. Seems they GM and LR officials were accidently seated togther. 232 ci Buick. Want a good book on Rover Engines get the book on Tuning Land Rover V-8s. Shows Rover engines inserted in all sorts of cars. Cobras, MGs, Triumphs etc. Has a guide on horsepower ratios. The 3.5 Litre is set with distributor while the later 3.9/4.0 are FI electronic Gems or Bosch. The 4.6 litre has lining problems, but you can get a better block from England with a 4 mil liner over the present 2 mil liner.
R
RonMacPherson
Be careful of any "super deals" you get.. They had a run of improperly machined motors where the oil pump feeds were NOT aligned properly.. worked fine for a few thousand miles, then oil pressure started dropping, noises... LR pulled the motor and replaced them (only adequate repair) and there were a number of short blocks at dealerships..
So if anyone says, "I got a sweet deal here, low mileage v8," pull the pan, check the bearings and pull the front cover to see if the pump holes are lined up...
I thought the engine was a 215 that was put in Buick Specials and Wildcats in 1963 & 64. They were also used in the Buick Apollo series. I have collected 3 engines over the years thinking I would get around to putting one into a MGB. Haven't gotten that far yet.
Marv
Mickey Richaud
Marv
Yep - 215. Not sure about Wildcats or Apollos, but definitely in the compact Special. Also used in Olds F-85's, and I believe they had a turbo version.
Redlacquer
Buick ancestry. Did they keep the buick olds pontiac bell housing bolt pattern? Would make it an option to swap in an iron v8 for those who are tired of Al engine problems, which buicks also have.
LarryK
Had 4 a 3.9, 2-4.0,4.6. Only dropped a sleeve in 4.6. 4.0 I have now at 175K miles.
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
S Rover 3.5 Engine Numbers Rover / Land Rover 2
S Rover 75.. NEW ENGINE!? WHY!!? Other British Cars 7
T Need Values for 2000 Rover 1.3 Twin Point Engine British Motor Corp 1
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
G Rover V8 interchange/swap question MG 9
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
weewillie rover p6 and nissan skyline Spotted 0
racingenglishcars Land Rover collection for sale - in Norway, Dec 4 Rover / Land Rover 0
S Looking for a Rover 215 motor. MG 9
