Hi All,
I just finished rebuilding my Girling calipers and getting the brakes bled is proving to be a tricky business, for me at least. I have just learned the proper sequence for bleeding the brakes. Left rear, right rear, left front and then right front. I am hopeful that this will make the difference. I had also read that some folks have had to resort to leaving a weight on the brake pedal over night? Any other thoughts would be appreciated.
New issue. I am installing new wheel hub nuts because several were rounded, broken and all were over tightened. Was successful with all except the last one! It rounded to the point where the socket was no longer effective. I purchased a damaged wheel nut socket kit and that didn't work. I did apply heat. I have since used a cold chisel and a smaller mechanics hammer and have failed there as well. I am sorry to say that I think that I am to the point of removing what is left of the bolt and nut with a hack saw and drilling out the rest. Does anyone have another idea? If not, which drill bit should one use on a case hardened stud? Another solution would be to put my tail in between my legs and take the car into my Healey mechanic and go ahead and endure the abuse that will most certainly ensue.
J7Bill
J7Bill
