rough running after long idle or long low rpm driv
Adrio
I am starting this thread as a result of something captainde said in his overheating TR3 thread.
"after fifteen minutes the engine idle was very rough, to the point where I had to keep goosing the throttle to keep it running, "
I suspect this has nothing to do with his heating problem. BUT I have that same rough idle issue with my TR4A. The engine in my TR4A is all rebuilt as are the carbs. It runs great, starts great and all that. If I let it idle for a long time (say 10 minutes then it runs real rough. The same thing happens if I am driving through a nice area looking at houses and trying not to make noise with my Stebro exhaust so I drive at 1500 RPM tops, after ten minutes or so I get that rough running. If I then run at high RPM for a bit it clears out and all is well again.
I assume its carbon fouling and the high RPM clears it.
Is there something that can be done about this other then high RPM clearing. Like different temp plugs or timing. I think my timimg is right, with just a very slight ping on heavy load .
Not a big deal but I thought there might be some interest and advice on the subject.
TR3driver
Great Pumpkin - R.I.P
Rumor has it that adding a heat shield to the carbs helps a great deal. Apparently modern fuel percolates easier than the old stuff did, so anything that keeps exhaust heat away from the carbs/jets should help. Increased air flow (electric fan) should help too.
Some have even reported noticing increased fuel mileage from adding a heat shield, presumably due to reduced fuel evaporation.
https://www.the-vintage-racer.com/webroot/Heatshields/
Personally, I just avoid driving slow
:driving:
T TR2/3/3A rough running after 20 min shutdown Triumph 9
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
N Stuck Needle Valve - Rough Running Austin Healey 15
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
B Thoughts...rough running at cruise. Austin Healey 3
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
tahoe healey surging and rough running Austin Healey 20
K TR2/3/3A TR3 Running rough..Cam or Carbs?How to diagnose? Triumph 10
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
R TR6 Rough running TR6 = Pertronix? Triumph 27
Woodie rough running Spridgets 7
S TR2/3/3A Rough Running TR3A - help with diagnosis Triumph 11
A TR4/4A TR4A running rough question[s] Triumph 11
Woodie missing, running rough etc etc Spridgets 25
J running rough / missing Spridgets 7
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
77MidgetMkIV Now running really rough-help?!?! Spridgets 15
beebopbogo Engine running really rough - 2 cyls? MG 8
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
C Rough Idle - What to check? Austin Healey 12
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
M TR2/3/3A Engine rough on acceleration Triumph 19
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
M Rough Idle MG 15
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
B diamond in the rough? Triumph 6
