TR6 Rough clutch when warm.
PDIGIO_6x3
72 TR6, I’ve recently replaced a throw out bearing and sleeve. Clutch seems smooth and normal when cold or first few miles. After running for 10 minutes or so, clutch operation becomes rough and seems to hang up. My suspicion is the bearing sleeve is getting tight when heating up. Anyone ever remedy this without tearing it apart?
I had this exact issue; it is really frustrating. I ended up pulling the tranny and greasing especially the main shaft really well and the issue went away.
Ok Robert. Yeah I’ve done clutches several times, always used a lithium grease on the trans collar for the sleeve. Never felt one this bad. I’m trying to see if there’s a way I can get through the slot on the side of the bell housing and miraculously feed a bit more lube in there. Not sure if it’s possible, just figured I’d ask.
Are the 2 locating dowel pins on the engine's rear plate to the gearbox in place ?
I had a very similar issue a few months ago. I ended up pulling the tranny and essentially painting the shaft the throw out bearing slides on with a synthetic brake grease. Smooth as silk ever since.
You do have to be carefull with grease, too much can get onto the friction disc. This will
do the opposite of what you would think. Makes the disc grab to the flywheel and not release
Mad dog
