Recently installed a new distributor cap (top entry) and rotor on my 61' Sprite. Also did a complete "Ignition Circuit Testing" as detailed in the Sprite Manuel (Section Ba.4). All tests passed (wiring, coil primary and secondary, dist.points etc.) except the "Rotor Arm Insulation Test." This test requires you to switch on the ig., hold the coil H.T. lead 1/8 inch away from the rotor electrode, and flick the points open: if no spark occurs the rotor arm insulation is satisfactory, if a spark occurs the rotor arm must be renewed. A spark did occur on my test indicating I should renew the rotor.
I'm not sure exactly what is meant by the rotor arm insulation; is it material inside the rotor, or is it the insulation pad underneath the rotor?? Input appreciated...
I'm getting a good spark from the H.T. lead into the dist. cap by no spark from the ig. coils (spark plug coils) so the rotor is screwing something up but it doesn't seem logical that that little rotor could cause so much trouble specially being brand new...advise needed... /ubbthreads/images/graemlins/cowboy.gif
