MGC Roots SC14 Supercharger Intake for a 69 CGT
DavidDCroy
I getting ready to pull the motor out of my 69 CGT to have it rebuilt. I intend to add a Cobalt rear shock link, Front tube shock kit, 7/8” Sway bar, Polyurethane bushings, Ceramic brake pads, After market rotors, All new New Rod, Main & Cam bearings, 030 Piston Set, Facet solid state fuel pump, Fuel pressure regulator with filter and a Dual Weber 45 Side-Draft conversion.
Has anyone seen a Roots sc14 supercharger intake, cooling and mounting kit for this setup?
Also is there any obvious mods I forgetting?
She needs some bodywork buts she is all original in Pale Primrose Yellow with Chrome spokes and an Overdrive.
Only 63,200 original miles.
Hello,
I have owned a couple of Cs. I am not sure what you’re trying to achieve with your modifications?
If you use Facebook, there are a few people on there that really know the stuff. Usually they fit triple Webers or 2” SUs.
Good luck!
