Roof vent position on BN7 hardtop.
Bundyrum
I am trying to find the dimension of the cutout for the roof vent on my BN7 Hardtop. I just need to know how far the cutout is from the upper trim piece for the window. I bought a hardtop and want to install the roof vent or at least cut out the hole before the top gets painted. Regards, Bundyrum.
DerekJ
I believe the vent itself was the type used in the Minivan at the time. The minivan was a panel van based on the original mini, it might be possible to source one of these vents from a supplier of classic mini parts. Only a few cars had these fitted and I doubt there is a specific ‘correct’ position for its installation. Just put it where it ‘looks right’ based on photos.
Healey Nut
I would source and get the vent before cutting the top .
I found one of the original style pop up vents on Flea Bay and will use it on my 62 Rally recreation.
I will post a Pic with dimensions later but again I wouldn’t go cutting until you have the exact vent in your possession.
Healey Nut
Pics attached of the roof vent I found on flea bay .
dougie
This might help you see the correct positioning on the hardtop itself.
B
Bundyrum
Hello Healey Nut,
Thanks for going to the trouble of getting the dimensions of the roof vent for me. I have put that part of the project on hold as I need to sort out where I am going to send the trim pieces to get refurbished.
Hello Dougie,
Thanks also for the photo, I was hoping to get a shot from side on if possible. It's always good to see an ex works car in any setting.
Best regards,
Bundyrum.
Michael Oritt
Bundyrun--
If your hardtop is factory there are, I believe, furring strips between the headliner and the top to which the liner material and backing, if any, attach. Not only will you have to take them into consideration when locating the vent and its opening but you will have to create similar strips to take up the space between the top and the interior trim ring. Over and beyond this where you mount the vent is your decision.
I am attaching a pic of my car and there is 10" between the outside edge of the ring and the rubber molding for the rear window but the 100 top is several inches shorter than that for the 6-cylinder cars.
John Turney
Good point Michael. There is a steel frame to hold the headliner. Bundyrum needs to miss the cross pieces. They are at the headliner seams. The vent should go between them. It probably would look best on the inside if it was centered between them. I don’t know if the factory rally cars had headliners, so it may not have been a consideration.
HealeyPassion
FWIW ... I agree with those that recommended not cutting a hole until you have the roof vent in-hand. Here are a few pics from an original Works Rally car I took in 2003 to help me place my roof vent in my Works Rally Tribute car. Hope this helps.
Happy New Year!
Cheers,
Steve
HealeyPassion
At the risk of taking this down a Works Roof Vent rat hole... I'll share the following.
Now at the end of the day very few people will care, so let's put this in the category of "no big deal". In fact, maybe there are even alternative opinions on this.
Here goes... when I visited Denis Welsh shop/store back in 2003, they told me that the "original Works vents" did not have the little flange at the bottom of the vent door (pic. 1 & 2). They said the originals just when straight down (pic. 3 & 4). I already had purchased the replica roof vent (pic. 1 & 2)... they had an original ... which I bought (in poor shape which I ended up spending more than the original cost to make right) (pic. 3 & 4). The final pic. 5 is the picture taken of an original Works Rally roof... also taken in 2003 at JME's shop in Leamington Spa (they have since moved).
Now is what DWM guys told me absolutely true? I have no idea. The Works may have used a later style on some of their later cars... I don't know.. I haven't seen them but that doesn't mean they couldn't have.
Pic 1 replica
Pic 2 replica
Pic 3 original
Pic 4 original
Pic 5 original
FWIW...
Cheers,
Steve
HealeyPassion
I would say DWR are correct. The most obvious difference between the original and the replica is the number of holes for the fixing screws.
I noticed that Healey Nut's find on eBay has the "correct", if that even applies, holes on the inside mounting bracket and different holes on the outside. It has the lip on the vent door similar to the replica that I had bought. I know these were originally sourced from the parts bins of the Mini Vans at the time (Hey, we need a vent in the roof - see what's in the parts bin). But I don't know if the Mini Van roof vents changed over time... seems unlikely, but stranger things have happened. The answer to that would most likely answer the question of what the AH Works roof vents looked like at the end of their run.
Side by side pic of replica (on left) and original (on right).
Cheers,
Steve
Healey Nut
Cheers,
Steve
i hadn’t noticed the mounting hole differences on my components. Now the dilemma is do I drill more holes in the inner plate or get my metal guy to fill the excess holes to make it look “ more original” ?
HealeyPassion
FWIW.... I'd fill the extra holes and use the interior mounting plate.
Steve
algot1901 Roof install Other British Cars 16
VeeCee MGB 1974 MGB Roof Installation MG 0
algot1901 50 Prefect wood roof support / bow Other British Cars 8
NutmegCT Garage roof insulation Restoration & Tools 37
T Up on the roof Spotted 2
HealeyRick Healey on the Roof - Sebring 1960 Austin Healey 11
P Travel "roof" cover? Austin Healey 6
Reh GT6 GT6 Roof Rack Triumph 4
K Leaky roof Jaguar 22
novashawn Swap my full sun roof for Austin S wheels ? British Motor Corp 0
T I may not have a roof...but look what I do got! MG 4
M Mk IX Sun Roof Removal Jaguar 1
MGBGT_noob I got me a roof! MG 1
L MGB-GT GT Sun Roof Revisited MG 2
MGBGT_noob MGB-GT MGB GT Roof Transplant? MG 7
TR6oldtimer While my new roof was being out on Triumph 6
red_tr250 GT6 Sliding Roof on a GT6 Triumph 2
L Sun Roof MG 6
mgbnew Red Light is off. Now a new roof. MG 6
V TR6 TR6 Fiberglass roof for sale/trade for steel one Triumph 5
D MGB-GT Rag roof GT... MG 1
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
