Roger got beaten up pretty badly over the cup holder recently and so I thought I might help relieve a little pressure on him, by sharing my installation of his idea in my BT7. When you are waiting around for the engine to be finished you do stuff like this!
A couple of small changes:
1. I believe my cup holder is a slightly newer model for a VW Jetta
2. I used the same aluminum strips for mounting brackets with JB Weld, but I used nutserts to make the install and/or removal really simple.
3. I installed the unit first with the plastic "folding door" as orginal, but decided it would look better if it were covered in the same vinyl as the dash fascia. What do you think?
4. Because I have a BT7 my install was to the underside of the parcel shelf rather than the glove box. In the BT7 the vertical height of the beverages is restricted a bit compared to the BJ8. However, it does not restrict passenger access.
So go ahead and let me hear your thoughts. Like Roger, I am building a driver (hopefully some long distances) so the cup holder does become a nice little novelty convenience.
You can click the slide show function or click each image if you like at the following URL:
https://web.mac.com/linwoodrose/iWeb/Healey%20Modifications/Cup%20Holder.html
Cheers and let's have it.
Lin
1960 BT7 in restoration
1959 Bugeye
Lin
1959 Bugeye
