Rod Bearing Clearances
red57
I'm wondering if anyone has any idea why there are different rod bearing clearances listed for the 100-6 engine and the 3000 engine?
Cranks are interchangeable with same the diameters, both standard and undersize, and the stroke is the same.
Bearing shells are the same part number and sizes.
AFAIK, the only real different between 100-6 and 3000 is the bore (the early 100-6 had clamped wrist pins as opposed to floating pins, and the gallery head, but still the same rod bearings & crank).
The Bentley Book, Haynes, and Autopress all agree:
Main bearing clearances are the same for both engines at .0013 to .0028
But rod bearing clearances are different;
100-6 - .0005 to .002
3000 - .002 to .0035
My machinist says, "You'll be fine if they are around .002"
OK, but any idea why the specs are so different?
Thanks,
Dave
Dandare
Just to add to the above (can't seem to find the edit button) I have looked in the workshop manuals for the BMC sedan models which used the 3L C-series.
The first, Wolseley/Austin (6/99 /A-99), shows the same clearance as the 2.6L motors ie .0005 to .002 [mains .0013 to .0028]
The later models (6/110/A-110) show .001 to .0027 [mains .002 to .0037]
What to make of that who knows!
Danny
red57
Thanks Danny, I have no experience with the sedans, but in the case of the Healeys, I was wondering if the difference could be due to the lower red-line and the rotary vane oil pump the 100-6 used (higher volume output at lower speeds)? Doesn't explain why the mains are the same for both.
BTW, for both motors, cam bearing clearances are the same at .001-.002 and end float is the same at .003-.006.
Crankshaft end float is also the same at .0025-.0055. So the only clearance spec I can find that is different is the rods.
Reading on line, several sites say to use the formula of .001 clearance for every 1" in diameter. So for the rods at 2" dia. would be .002 clearance and mains at 2.4 dia. would be .0024.
I've talked to a couple of other machine shops and they seem to agree that Mains around .003 and Rods around .002 are good targets (they add a bit to the mains clearance to account for the flex of the long and heavy crank with only 4 mains). I even talked to a polymeric bearing coating company and they said the same. It appears to me these shops use their experience and understanding of modern oil formulations more than the 60 year old "book" in most cases. Mind you, no one was offering me any guarantees......
Dave
Dandare
Dave,
I tend to think that the real reason for the differences is just the usual inconsistancies and mistakes/misprints among BMC's printed publications and data.
Danny
7 948 sprite chewed the number three rod bearing MG 10
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 5
F Main / Rod bearing sizes. Spridgets 6
G 149081/5105 STD 1500 rod bearing? 149082/5106 STD Spridgets 4
Basil Rod Bearing bolts Triumph 11
Healey Nut BT7 Panhard Rod Austin Healey 28
Walter74 Steering Rod Installation Austin Healey 6
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 1
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
R Upgraded rod bolts for stock rods Austin Healey 1
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Drone Dog connecting rod stamps Austin Healey 1
Feathers 289I inner tie rod end. TVR 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
KVH General Tech Plasti-Gauge on Rod Bearings Triumph 13
S TR4/4A Fascia support and shift rod boot Triumph 0
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
JPSmit Two words: Rat Rod Other British Cars 1
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
S TR2/3/3A DIY radiator rebuild and rod out Triumph 26
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
Csarneson Connecting Rod Bolt Question Austin Healey 3
KVH General Tech Lubricating New Rod Bearings Triumph 7
