Rocker Repair Plan
Re: Not all rockers are equal
It's safe to use boards under the tires...just nail the tires to the boards and they won't move !?!?!?!?
Norton, this was my first ever attempt at body work with a dolly and hammer and I have to admit I screwed up one rocker on my first attempt. The second went better.
Norton47 said:
Did you move the depressions for the fenders to gain back that 3/8" inch and get the better fit?
I tried to, but finally just bit the bullet and used a little short fiber glass strand filler on each end to gain the fit and shape I needed. I also used body filler over some of the dings I made while shaping.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
What did you use to form over to sharpen the long runs, seems like hammer and dolly work would be hard to keep even enough over such a long run. [/QUOTE]
These were a challenge. The first thing I did was to get the step bends under the door to the 90 degrees of the original. I did this by running an oxy/acet flame along the back side of the crease just enough for it to start turning blue. As the metal cooled, it shrank, causing the bend to tighten. I then used the sharp end of a heel dolly and off dolly carefully worked the metal to flatten and crisp the edges. A similar technique was used on the front extension under the fender once the crease lines were established.
The lateral bending, do the ends bow away from the car or does the center bow out? I would guess this is due to the stamping process?
[/QUOTE]
Each end flares out from the depression for the fenders. On the rear extension I initially cut (vee notched) excess metal out so I could pull it in to fit the end caps then welded close the notched seam. I also used the torch to shrink the metal in places. On the front, I just worked the metal (with some shrinking) and allowed the excess to flare out toward the top, which when trimmed was welded to the outside of the foot-well bulkhead.
When I finally got the rocker to where I wanted, it fit without having to force anything.
Think it through and go slow, it looks like a lot of work, and is time consuming, but I got a lot of gratification out of the effort.
It looks very good Ray. Great job!
