Quickly developed a noticeable tapping this weekend on my BJ7, and have identified a single rocker that is not oiling where the adjusting stud meets the pushrod. The ball joint is perished.
A couple of questions.
1. Assuming I haven't scarred the rocker shaft, is it OK to replace the bush on only one rocker?
2. Can I simply replace the one pushrod?
Motor is fairly fresh rebuild; I can only presurme the oilway was misaligned on the rocker.
Thanks in advance.
Thanks in advance.
