Rocker On! [sort of]
Crisis
I removed the valve cover on my 73 TR6 to set the clearances and look what I found while cleaning up.
I hope no damage has been done; I don't see any.
Is there a way to prevent this from happening? Will threadlock stick to something covered in oil?
I appreciate any advice, thank you.
Merlin63Tr4
Ouch is right! There is supposed to be a cupped star washer under the head of that screw, did you find that? :wall:
Moseso
Crisis said:
No I did not. I better look, but really, where could it have gone (nervous laughter)?
Right down the same hole that screw dried to dive into -- in which case it is sitting near the tappet. If it gets into the tappet, it could make a real mess of your push rod.
Or you could be really lucky and find it still on top of the head. That would be a huge relief! Look everywhere. Use a magnet.
TR4
Maybe the washer never was installed? That would be one reason the screw came loose. I would be checking to make sure other required washers are there.
Moseso
Looking closer at the picture of the empty hole in the alloy rocker pedestal, I don't see any indication that the star washer was ever in there. IIRC, it left definite marks in the countersunk hole on mine.
Brosky
Examine the tapered countersink to see if there is an imprint of a star washer in there. If so, get the magnet out and be prepared to remove the rockers, so you can remove the push rod to get a clean view down to the lifter. You do not want that washer getting between the cam and lifter. Unlikely that it will happen, but do your best to insure that it can't.
cheseroo
I suppose if you are super-duper lucky it falls into the sump where it's too big to get sucked through the oil pump inlet screen and it lives out the rest of it's happy life in a hot tub (of sorts).
Minesweeper
I don't think you need worry about the washer since the TR6 doesn't have a star washer on that screw. That screw not only locks the rocker shaft in place, it also prevents oil from gushering up out of the hole in the shaft, thereby directing the flow of oil through the rocker shaft galley to each the rocker arms. Having a star washer on the screw would allow a quantity of oil to seep by the screw instead of directing it all of it to where it is needed. Since the screw became dislodged, I would remove the rocker assembly and inspect the shaft for any damage that may have been caused by insufficient oil delivery to the rocker arms.
As far as ensuring this doesn't happen again -- I think it's just one of those things you have to check periodically. Owner's manual says to check valve clearances every 12k miles (which would be about once per year on a daily driver), so I check valve clearances (and that screw!) every year even though my milage is much less. Same with oil changes, lubing grease fittings, etc.
Scott
bgbassplyr
When you reinstall the screw, lightly stake it to the pedestal.
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
Rut Which rocker assembly? Spridgets 7
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
Scot1966 TR6 TR6 rocker panel fit Triumph 6
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
