T
Tinster
I believe a defect in the manufacture of my existing rocker arm
shaft is the cause of dry rockers No.12 and No 1.
I have a new shaft ordered and some almost new rocker arms gifted,
in case any of mine show excessive wear.
My question: I have never seen a TR6 engine operate, except
my own. With valve cover off, at full operating temperature,
my rocker arms oil holes "seep" oil. One tiny drop at a time.
Is this correct? Or should oil flow swiftly out of the 2 oil holes
in each rocker arm. Thanks, Dale
My pushrod for valve No.1 spins but is dry of oil. No 12 has
plenty of oil.
I am hoping the new shaft will correct the existing problems.
Photo of what I think is the defect in the existing shaft.
Defect in oil channel to rocker No. 12.
plenty of oil.
