Looking at my front rocker arms through the oil filler pipe while the engine is turning about 1500 RPMs and up to temp. I see a very small amount of oil bypass dripping out the rocker arm weep holes. The top of the head is a little wet with oil, but not as much as I think it should be. Is this typical of the 18V engine or should there be more oil flow to the rockers? This engine has only 500 miles on it and runs 55 lbs oil pressure at 2000 RPMs hot. /ubbthreads/images/graemlins/confused.gif PJ
