BN6_2197
Gents,
started to remove my king pin due to lubrication problems at grease nipple 99 (see attached picture). I tried to remove the Fulcrum Pin (77) but I was unable to remove it even with a lightweight hammer. Is this expected? Is there a specific order of the parts to be removed? My idea is to
Any comments on the procedure welcome.
Regards,
Volker
- start with the steering lever (for that I have to remove the brake drum first I think)
- then the Fulcrum Pin
- after that all the parts at the bottom of the King Pin (38-42) and
- finally the slotted nut (23, 24).
Regards,
Volker
the last time I had the engine out for refurbishment and then decided to drop the front suspenders, that was a bit hairy, come to think of it I did use Randy's method eventually for dropping the pan then, it could not readily be done with the jack as there was no weight to counter the springs.
Just one thing: which lenght and diameter are recommended for the rods?
