71tr
How do you know if the TR6 ring gear is worn or should otherwise be replaced? If the teeth are in good condition and the starter engages is it better to leave well enough alone? Now, if you just happen to have the engine out of the car should you go ahead and have the ring gear changed-out while you lighten the flywheel and change the clutch? Finally, the factory ring-gear was installed with the chamfer towards the transmission, presumably to accomodate the early 250 style starter which engaged from the rear. It seems intuitive to install the new ring-gear with the chamfer towards the starter motor.
