Luke_Healey
My '66 Sprite has an issue with the turn signal circuit on the passenger (righthand) side. When you flip the turn signal lever up, the lamp on the dash breifly illuminates once and then does not illuminate any longer. The front and rear signals both blink, but you don't get that reassuring click-click from the blinker under the hood.
Then, when the parking lights are turned on, the turn lights no longer blink, but they do illuminate solid.
I started by taking apart the turn signal switch on the steering column and verified that it's working properly (I flip-floped the wires to the left and right side to verify this.) Then I pulled the rear right signal lens off to verify that the bulb socket was clean and the whole tail lamp housing was getting a good ground, which it is. Then I pulled the front turn signal/parking lamp housing to do the same.
Since the blinking stops when you turn the parking lights on, I thought maybe the parking lamp and signal lamp were wired backwards or something, so I pulled off the grille and got into the wiring up under the nose of the car. Everything is wired correctly, I think.
This is where my main question comes in... Are the parking lamp and turn signal circuits completely isolated? And since mine both affect the other, where might I look for shorts or miswiring? The wires that come out of the front parking lamp housing are a red one and a green/white one.
Thanks for any help.
Hi Guest!
