bighealeysource
Hey all,
Read the recent thread on an intermittent blinker ( Ok Reid I know that is redundant !)but I have the right side blinker that flashes quickly versus the left side that flashes along with the turn signal relay clicking with it. Turn signal relay on the firewall does not click when the right side is switched on via the trafficator switch but as said above it does flash but rapidly. I have checked all the connections and made sure they are tight, etc, did not check flasher relay yet. Does this sound like simply the turn signal relay unit ( small one) on the firewall? Running light functions fine on both sides and fast blinking is same front and back on right side. Any suggestions or might just let it go since it does work. This is on 56 BN2.
Thanks,
Mike
Thanks,
Mike
