TR2/3/3A Restoration of 54 TR-2
Redoakboo
I have recently re-installed the rebuilt engine in my TR-2 and am starting to complete the wiring. Question: I turn the engine over with the crank to try to circulate the oil that is in there. By turning with the crank, will the oil pump give enough pressure to see oil on the valve train?
Dick
CJD
If you properly lubed the engine during assembly it should be good for a couple years. Using the starter to turn the crank takes several minutes to get enough oil through the system, and you are likely doing more harm than good with the dry cranking. Most wear on engines is during the cranking/starting. I would recommend leaving the engine stationary and loosen the rocker shaft to relieve the valve spring pressure, if it will be more than a year before the final start.
Also, do not add oil until ready for the initial start...remove the valve covers and ensure all goes down the lifter bores. If you can fashion a special oil drive from a worn out distributor, use that with a drill to circulate the oil and build pressure immediately before the initial start. if you don't have an old distributor to fashion a primer with, still use a screw driver with a drill to ensure the pump has primed and is providing oil. Then replace the distributor and crank it up.
The goal for any new rebuild is a start with the minimum cranking time possible, so ensure the fuel system is primed, a fresh battery, valve adjusted, and you have a spark with close enough timing for a quick start.
TR3driver
Great Pumpkin - R.I.P
To answer your question, it takes a long time to start seeing oil at the rockers even with the engine idling. I'm pretty sure you could get there with the hand crank (and the plugs out), but there is no way I would want to crank on it that long.
Because of the way the camshaft meters the oil to the rockers, the oil gauge actually comes up first, before any flow is visible to the rockers. I've never put a stopwatch on it, but I'd guess it's close to 30 seconds at 1000 rpm before the rockers start oozing oil; so something like 500 turns of the crankshaft. And that's for a normal start, where the oil filter is already full, etc. (I often leave the cover off after checking the valve lash, and start the engine to make sure all the rockers are getting oil. Never had a shaft plug up on my own engines, but I have seen it on others.)
IMO the bit about most engine wear being at startup is a myth, often repeated by the likes of Slick-50 and STP (both of whom have been censured by the FTC for lying in their advertisements). Also, on the TR2 (unlike most engines), the oil pump literally sits down under the oil; it doesn't need to be primed. Just spinning with the starter (plugs out) puts very minimal load on main and rod bearings (which of course you greased during assembly), and not much load on the camshaft journals, etc (due to the low speed), which again were generously greased. "Back when", many engines ran with only drip lubrication to those points anyway. If you attend any antique power show, you can see a long line of engines with their rockers fully exposed to the outside, and no lube at all beyond the occasional squirt (by the operator) from an oil can.
Anyway, I've always just spun it with the starter until the gauge comes up; then put the plugs in and started it. I've run well over 100,000 miles, and never seen any signs whatsoever of excess wear on initial startup. Besides which, you actually want some wear right at initial startup, that's the "bedding in" that the manual talks about, and the reason you don't use super-slick oils for the first few hundred miles.
A stock TR2 is going to have it's life shortened a lot more by the primitive air filters, than by being started without oil pressure.
TomMull
I've never been able to do this although it's been recommended often. If you try to spin the oil pump with the distributor drive, you wind up spinning the cam and engine with the drive gear which is not practical to say the least. If you remove the drive gear and spin with a screwdriver, there is nothing to seal the pump cavity and you can't build pressure. Looks like you might be able to spin it with an spare oil pump drive shaft or separate the one you have from the gear, which I have not tried. I'd like to hear from someone who has.
Perhaps another reason to use the starter.
Tom
CJD
Fortunately the TR cams are very mild and the engine forgiving. In a high lift flat tappet engine, spinning a fresh motor with the plugs out will kill the cam, as the cam sees no lubrication until the crank starts slinging oil at speed. If minimum cranking prevents killing a performance motor, then it must be good practice for even a tractor motor.
CJD
Just had a memory pop up. I really don’t know if wear occurs most at start up, but I do know the really pricy engines, like Rolls Merlins, Wrights, and many industrial diesels came from the factory with pre-lubes. Those building real horsepower seem to think oil pressure for starting is important.
A 100/6 BN4 Restoration Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Greg Chait Wanted Stalled or Abandoned MG Restoration Projects MG Classifieds 3
H General MG MGYB--Semi-- restoration MG 2
D My new restoration tool Restoration & Tools 13
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
JoeO 72 TVR Vixen hybrid restoration TVR 1
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
D Fascia Restoration Austin Healey 14
J Restoration Progress - Boot Installed Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Tr4 restoration books Restoration & Tools 2
F YouTube Healey Restoration Videos Austin Healey 5
R TR2/3/3A Re-start after total restoration Triumph 22
F GT6 Looking to sell - in progress restoration Triumph 19
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
Don Riicardo Reliant Scimitar GTE se5a restoration Other British Cars 23
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
C SoCal Restoration Shops Austin Healey 15
HealeyRick Coronet Cream Restoration Austin Healey 1
H Restoration Magazines and Books Spridgets 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
Got_All_4 TR6 Starting my frame restoration Triumph 32
F General MG Field find restoration question ... MG 5
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
S TR2/3/3A Frame off vs. body on restoration Triumph 21
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
V TR2/3/3A TR3A Chassis restoration Triumph 8
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
A TR2/3/3A Restoration work near San Diego CA Triumph 2
JPSmit Restoration on a Budget Restoration & Tools 4
F Restoration Guide Austin Healey 2
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
T General TR Ron's Vintage Auto Restoration - Salado TX Triumph 2
C Looking for SoCal restoration shop Austin Healey 4
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
J TR2/3/3A Starting my TR3 A restoration Triumph 8
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
