Restoration Modification Recommendations
Scotsman
Planning a ground-up restoration of a BJ8 MkIII and wanting recommendations on areas UNIQUE to these cars that are known weak spots and should be carefully inspected and possibly strengthened.
Also any suggestions on highly recommended improvements that would improve drivability would be welcome.
Want to try and avoid the situation where I go “I should have done ****** when I had ****** apart.”
As an example, the chassis suspension brackets on IRS Triumphs were known to be failure points and it’s highly recommended to add reinforcing gussets.
Modifications & Upgrades (to our 1962 BJ7 (the Mk II with real roll-up windows):
Bling:
Moto Lita steering wheel
Fuzzy dice (optional)
Convenience:
moved windshield washer tank and cage from 3” diameter hole parcel shelf under dash to same size hole in fender/chassis reinforcement under right front fender
cigarette lighter/power take off installed behind dash
battery operated motorcycle clock replacing the o/d switch
flat pin battery charger connections to battery
I think that we added wood shims (didn’t use vehicle in 2026) under the seat rails to add a bit of rearward tilt for the seat backs
For long trips, find the pieces of seat shaped foam in the garage and add them on top of the bottom seat cushion
Add a GPS unit. With our BJ7, we used magnets to hold it to the heater box
Corrosion:
RustChek
Lubricants:
Oil and filter change about 7.25 litres of Shell Rotella T4 15-40; Castrol Edge 20-40/50; Valvoline VR-1; etc. 1200 ppm ZDDP is a good idea (flat tappet engine)
Oil filter WIX 51374
Mechanical Upgrades:
Replaced stock 4 speed transmission and overdrive with an all synchromesh Toyota W Supra five speed. Kept the stock Healey shift knob.
I believe that the clutch assembly has been updated to the BJ8 style, but am not sure
Obtained a Lempert 3.54 differential to replace 3.91, but not installed as of yet (had been misassembled and has a whine)
Harmonic dampner
New main rear engine seal
Stainless steel exhaust system
Pertronix ignition (check: may have been replaced, as the Pertronix tends to burn out if ignition on without engine running)
Spin on oil-filter WIX 51374
K&N air filters
Replaced SU fuel pump with updated pointless electric
Red-Line oils
Misc.:
  • Engine is low mileage (75 ,000 miles but one cylinder is bad and needs rebuilding. Not sure if the scoring on the walls can be attributed to its infrequent running such oil will have left the walls since the last time it cranked over. Probably should have used fogging oil in the autumn as part of storage, or squirted oil down the spark-plug holes each Spring. We did (sometimes) add 2 stroke oil to the gasoline in the Spring
  • Moved the windshield washer fluid container from the parcel shelf within the cockpit to the ‘hole’ in the chassis supports on the passenger side, in the engine compartment, below the passenger side fender
  • We did replace the oil pressure spring at some point; oil pressure has never seemed as high as expected.
  • Fuel gauge is empty when it reads 1/8 full. Not sure what to do.
  • The new wheel/tyres are a tight fit under the boot- keep an old one for a spare
  • A friend fabricated a steel with a roller at each end that will fit over the knock-ons and is turned with a ½” breaker bar. Include a snipe in the boot. Alternatively: custom made hammers or a chunk of 2x4 and a short-handled sledge
Safety:
added vacuum assist for brakes
three-point seat belts in front and lap belts in rear
rear reflectors converted to signal lights
brake/tail lights replaced with LEDs
added quarter light mirrors (rectangular look better; circular provide better rearward view)
4 way flashers. Knob added to dash. Note that the signal light dash indicator is not triggered by the emergency flasher.
original Armstrong lever arm shock absorbers
Stainless steel brake lines
Tyre Pressures:
Try 30 -32 psi front/28 psi rear; 32 in the spare
Weight is about 52% front and 28% rear
There was at least one thread open (years ago) with similar content - good fortune searching!
And, yeah, a BJ7 isn't the same as a BJ8, but I figured that there's enough overlap that this will hopefully be useful.
Good Fortune.
Doug
I tried to upload my build sheet, but file is too big for server; post your email and I'll send it to you. Welch DW1 gun-drilled cam; allegedly 'slightly better than stock' (new tappets required). Forged pistons are overkill for a stock engine, but why not? I second Pertronix Ignitor; engine runs better and I've got two old tractors if I feel like futzing with points. I have the 'Lempert' 3.54 installed; a must for freeway cruising at the expense of off-the-line performance (you ain't gonna beat a V6 Camry anyway). A little whine only noticable with hood up (which I rarely do). Vernier timing gears.
It's somewhat controversial, but I have PCV valves on my BJ8 and BN2/100M. Likely limits oil loss, and keeps oil cleaner.
Since you're in Portland, I recommend visitingTom Monaco at tomsimporttoys.com. He sells Moss parts at 5-10% off and is always williing to help.
re: 'Weight is about 52% front and 28% rear;' what happened to the other 20% :p
Addendum: Not for purists, but I like my shift lever-mounted O/D switch; you don't have to take your hand off the shift lever to engage the O/D. I have it and the fascia switch wired in parallel so either can engage the O/D (but both have too be off to disengage). Also provides backup though, strangely, they became intermittent when the dash switch self-destructed (I still haven't figured out why, both leads were ganged-up at the switch).
They were fitted to the works rally cars I believe. I made one for a friends' BN2.
Hi John--
I have yet to install it but recently purchased a three-position bat-handled toggle switch for the headlights that will mount on the right side of the dash between the fuel guage and tach: Up=brights, Middle=lows, Down (momentary)=flash brights. The toggle handle is long enough so that I will be able to flick it without having to take my hand off of the wheel
I like the idea of the dead pedal--did you fab or buy it and if so where?
