Restarting my engine...after a long sleep
G
Since my engine has been asleep for about 3 months, with all fluids drained (oil and coolant), should I be concerned about the initial cranking? I will refill everything this week and plan on cranking her over the weekend. This counterclockwise spinning of the oil pump through the distributor shaft hole seems unnecessary to me. Any thoughts. Besides, how is one to get a drill-driven flat blade into this opening and engage an offset drive dog slot and expect it to rotate? Am I missing something here?
Not far behind you, Tinster!!!
Oh, and all my terse comments about Dale and his Cryptmobile were done with tongue in cheek. Tongue in cheek because my tooth still hurts.
tomshobby
Hi Bill,
Unless you took it apart, meaning the cam out or the bearing caps off it should be fine just like you left it sit for the winter.
However, for peace of mind you could remove the spark plugs and turn it over a couple times to fill the pump and get some oil moving through the lines. Then start it up.
This is much different than the critical break-in of a fresh engine.
Would like to be where you are, it will be 2 or 3 weeks before I will have mine on my engine stand. But if the machine shop can get things done I should be running by May 1st.
AweMan
Bill:
I would definately remove the plugs and as an extra precaution even give each cylinder a squirt of oil {Not too much} just enough to lube and seal the rings. Then give the engine a good spin to {As Tom said} fill the Pump and oil gallies. When you fire it up let it idle {hopefuly it will} until it comes up to operating temp.
Good Luck!
Brosky
I would use a shot of Marvel Mystery oil in each cylinder.
bailee2
I woke my first restoration (55 Ford Truck) up from the dead with Marvel Mystery Oil. I will vouch for its lubricity.
1972 TR6 in restoration
1959 TR3A
M38 Army Jeep
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
TheAssociate
Whenever I have resurrected an old engine that hasn't been run for a while I crank the starter a few times for about 30 seconds each with the coil wire disconnected after I change the oil.
Adam.
____________________________________________________________
1973 Triumph Spitfire.
T
Tinster
Hey Dr. Bill!!
When I first got Crypty's engine to fire, I had to
use a spray bottle of gasoline and spray fuel
directly into the intake manifold.
This is kinda dangerous so have a fire extinguisher
handy and an escape route planned for a quick run
away in case of fire.
Be advided, this technique will result in extreme
high RPMs so cut the ignition switch off almost
immediately. Use with caution as this is a really
bad idea and should be attempted only as a last
resort- like with the Crypt car.
PS- Crypty started up last night and I took a ten
minute spin with no break down.
d
Brosky
" This is kinda dangerous so have a fire extinguisher
away in case of fire. "
Dale,
Your method of starting would never have been approved on this forum, had you posted it here prior to using it. With that being said and the fact that you are now a seasoned, trained technician, we all know that you were really trying to blow Crypty up a long time ago.
No wonder that car hated you so much. See how nice it is since David treated it so gently.
T
Tinster
Hey Paul!!
Not my original idea at all.
I never would have thought of it.
Someone here posted the suggestion
to me. I thought it was kinda standard
practise.
I stand corrected. Thank you.
d
swift6
I Think it was one of those methods of last resort to see if you could at least get that engine to fire.
BTW Dale, did you and David get the timing and distributor clocking straightened out as well.
Another quick question out of curiosity. What is considered a 'Long Drive' for you there on PR?
Brosky
" I Think it was one of those methods of last resort to see if you could at least get that engine to fire. "
Correction - I Think it was one of those methods of last resort to see if you could at least get that engine "AND CAR TO CATCH ON" fire.
Shawn,
Are you sure that there wasn't a subliminal message in there somewhere?
Dale, I'm just busting your stones a bit. I'm bored with no Crypty issues to solve and you happily driving along every day. However, my boredom today is NOT an endorsement to start any suspension work. Just keep driving....
tomshobby
In the 1970's the Army had a tracked personnel carrier. It did not want to start in cold weather and guys would spray either in the intake. The problem was that there was a pre-igniter for cold weather starting that came on automatically when the start switch was turned on. It worked great with diesel fuel. With either, well there were a lot of aluminum intake manifolds replaced because all the pieces of the old ones were so hard to find.
T
Tinster
Shawn:
1. David re-timed Crypty, looked at the dizzy and
said to leave well enough alone. I concur.
2. A LONG drive in PR?
A. In the Crypt Car a 15 to 20 mile drive
that begins and ends in my garage is an
exceptionally long drive by Crypty standards.
B. In the Grey Ghost a 2 1/2 hour (80 miles) trip
to Rincon on the other side of the island is a
long trip by local standards. Three hours is about
tops to get from any point on the island to the
furthest away.
C. In Tres Gatos a 5 to 7 hour voyage is a long day.
dale
T
Tinster
What do you think Paul?
Now that Crypty is operational, there are
fluids leaking onto the garage floor under
the rear end.
Since every gasket and oil seal in new, should
I just add brake fluid and differential oil and
drive Crypty for a while?
Or bite the bullet and take apart the rear end
and replace all the gaskets and oil seals?
They probably dried out during the 11 months
of being dead.
What is your opinion?
d
70herald
the rear end.
This is an English sports car. They all leak fluids: that is how they mark their territory.
of being dead.
No, those seals didn't dry out in 11 months: 5 years maybe. Either there are small scratches worn into the drive shafts or the oil is coming out some other way. As long as it drips you know that there is still at least a bit of oil left in the car. Just check it every week until you get a good idea as to how long it takes for the oil level to drop. Then you will know when it will need refilling. Have fun driving.
Andrew Mace
the rear end.
drive Crypty for a while?....
Needless to say, I'd want to determine exactly what fluids are leaking! If it's brake fluid, find the source of the leak and FIX IT NOW!
If it's gear oil from the differential, don't panic just yet. It could be as simple as a clogged breather causing pressure inside that, in turn, forces the gear oil out at any point it can!
Check out this diagram from the Moss Motors web site; number 4 shows the split pin and breather location. Odds are there's a good bit of road grime piled up there. Clear that away, and odds are the leak(s) from the diff. will diminish or go away completely. Lots cheaper than pulling the diff and replacing a lot of seals and such if you don't HAVE TO! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Brosky
Follow the advice here of washing everything down and then determine where the leak actually is. Then you can address what to do. Don't start by ripping everything apart until you know for certain exactly where and what are leaking.
You're up and running now. Let's keep it that way by doing ONE project at a time.
swift6
Tinster said:
Shawn:
furthest away.
dale
1) Sounds like a plan! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
2) The reason that I ask is that a good way to build confidence in a car that has been questionable before is to slowly make longer and longer trips. Doing it that way does two things.
A) It keeps you driving it. Remember how we said these cars like to be driven? If they sit too long things go wrong. Regular driving mean regular maintenance but the maintenance is usually easier than repair.
B) As you continue to venture further from home, your confidence in the reliability of the car builds.
Before you know it, you'll be cruising to the far corners of PR in your TR. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
T TR4/4A Restarting an engine - oil pressure problem Triumph 6
H Restarting my restoration Austin Healey 7
19_again MGB Stalling and then restarting after 4-5 minutes MG 32
T restarting after six months Triumph 2
T Trouble restarting after a drive Spridgets 11
Y Restarting a stored Europa issues Part #2 Lotus 0
Y Restarting a stored Europa issues Lotus 1
P AH restarting after 7 years no driving - coil Austin Healey 9
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 11
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
