My 73 TR6 will start cold, usually, on the first try. However, after driving it for 10-15 minutes...enough time for the engine to get heated up, it is very difficult to restart. I've noticed that the longer I wait to try to restart it, the more difficult it gets to start. The engine cranks fine...no electical issues. Its got to be something to do with the Air/Fuel ratio but I'm not sure.
I've installed one of those aftermarket heatshields intended to reduce the radiant heat from the manifolds to the bottom of the carbs, but this has had little, if any noticable effect.
...I'm sure the + 100 deg F. heat in California isn't helping too much either.
Any advice?
Any advice?
