TR6 REskinning TR6 Doors
hondo402000
I decided to have my doors reskinned, after removing the paint there were a lot of holes and welds at the top front and rear and on the DS a bunch of dents that I dont feel good about just bondoing them up, so has anyone reskinned their doors, I have seen it done on youtube and it looks fairly easy and they have a pretty cheap crimping tool to fold the edge over
Hondo
tomgt6
All I know is body shops don't like to do it. I talked to them about doing one for my car and they charged about double what it would be to buy a new door.
I am not sure what that means but it means something.
DNK
My suggestion after having mine done. Have them align the skins with the doors on
TR6oldtimer
I have door skins yet to be installed. Not really sure whether I will do it or try and farm it out, but not at twice the price of a new door!
What has me a bit concerned doing it myself is the process of hammering over the fold without distorting the outer panel. This is especially troublesome on the top curve of the door.
And yes to Don, before the skins are tacked or epoxied into place, they need to be fitted to the car and aligned.
Oh, on that crimping tool, I used one when repairing a fender, it gives a very sharp thin edge. I prefer the more rounded edge you get from working with the hammer.
I think I will wait until you have done yours and report back to us...
DNK
Ray, Please,Please don't ask me how I know.
mallard
Sometimes the skins will oilcan on you if you don't get them just right. You might want to consider repairing the doors you have, or look for replacements. Keep an eye out for Phoenix Craigslist under Triumph parts. They do come up at times.
tdskip
LOL Tom.
hondo402000
hondo402000
well I will definately go the 3m pannel bonding adhesive route and then fold over the edge either hammer and dolly or the tool I ordered, and with the doors in place to get the alignment, the TRF book say in Rodger williams book how to restore tr250 and tr6 there is a part on door skinning ,, anyone have the book and willing to scan the few pages and pm an email, When I get the door skins in I will decide what I am going to do and call around, My door skins are in such bad shape too much welding to do to patch all the holes and cracks and dents
Andrew Mace
Reskinning a door: yet another body shop task that seems mostly to have gone the way of lead-loading and metal shaping in general. But such are the economic realities of shops that do primarily collision work, I suppose!
Many years ago, my dad brought home a deaccessioned book from the library; it was a late 1940s auto body textbook. Most of the techniques are still valid (although I suspect most shops no longer line each side of a to-be-welded seam with wet asbestos paste!), but some of the tasks they show are jobs that just plain wouldn't be done except maybe for a beginner to get some practice on a skill he/she might never use.
hondo402000
hondo402000
well the door skins will be here tomorrow and I will be home on Thursday, so I will get to access the project. I purchased the 2 part urethane body adhesive today only 42.00 and then the 50.00 application gun. working time 70 minutes at 70 degrees, that should give me time to hammer over the edges and get it on the car and be able to move the skin a tad to get the seams to line up. We shall see
Hondo
trfourtune
I've done them. Not as difficult as you might think. If the skins come with the edges pre-bent 90 degrees, you can "help" them over with the wide flat vise grips first to get them farther over. ease the whole edge over gradually all along the whole edge, a little bit at a time. When you use your hammer, make sure you keep a (flat) dolly on the opposite side under the edge. I have found that after removing the old skin, the edge of the inner door panel is usally rusty and should be sand blasted to clean it up first and painted. The door gets all wobbly when the old skin is removed. Take the door off and install the skin loosely! install the door, line it up, move the skin around on the inner part of the door and adjust hinges for perfect fit. THEN, tighten the skin to the door (on the car) and adjust the squareness of the door to avoid a big twist. Tack weld,check fit as you go, seam sealer, done.
I like to pre-paint the inner of the door skin first since they usually come only primed (not water proof-epoxy primer required to be water proof).
Rob
ps-I'm no expert but that's how i do it. (my dad's a retired bodyman with 40+ years experience-always had a car on the go inthe garage while i was growing up- i learned a few things).
hondo402000
hondo402000
thanks TRfortune, I didnt think it could be as hard as some say but I do have the ability that some dont, here are some pics of the progress, the color is super red, not original but dont really care
hondo402000
hondo402000
just finished painting the inside of the door skins, left bare matal around the edge for bonding adhesive as required by directions
TR6oldtimer
I know you are going to do this, but just in case, a simple reminder to be sure to apply your sound deadening material before you put the skin on.
hondo402000
hondo402000
Thanks, almost forgot about it, so what should I use, dont think I can pull the old stuff on the old skin? Any suggestions?
Hondo
TR6oldtimer
Hondo, I used two layers of Dynamat Xtreme inside the tub where the original stuff was, and plan to use it on the doors as well.
There are other products out there that I am sure members will bring to your attention.
The old stuff is asphalt based, so if you heat it from the outside of old door skin you might be able to peel it off. Once removed, I am not sure how well it will adhere to the new door.
IMO, it's best to go with modern products.
hondo402000
hondo402000
ok driver side door, the skin is on, surpriseingly it was fairly easy, the skin zipper I purchased is a POS so dont bother unless you are skinning your doors with tin foil, so a hammer and rubber sanding block worked just fine, I tack welded the top but glued the whole skin so when it sets up should be good, the only minor body filling I will have to do is where I used the skin zipper, very minor though
J Reskinning Steel Hardtop Interior for Winter Triumph 2
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
