MGB-GT Reproduction light switch
Crazyman60
Just got started tinkering with my newly acquired ‘72 GT. I began replacing different switches such as the hazard switch blower switch and lastly the light switch. I needed to get my state inspection so I that I can drive it. Everything inside is beginning to coming alive again, until tonight. I pushed the light to turn headlights off and switch broke, it would not move. I took the switch out and it had melted. Any ideas?
bobhustead
Check also the wiring diagram to see if there is a relay someone might have bypassed thus passing the whole load thru a switch not designed to handle it.
C
Crazyman60
Thanks. There no telling how many hands have been on this car in the past 50 years. The original switch was broken internally but there was any sign shorting. The bottom of the steering column and behind the console, I found lots of spiced wires.
bobhustead
I looked at Moss catalog and find no mention of a light relay. I say you have a short that you need to track down.
C
Crazyman60
Until a day ago the lights were being turned on for short periods. I got the safety inspection done on it yesterday and I have been driving everywhere with the lights on. One thing that I forgot to mention, The tail lamps stopped working right before leaving for the inspection. Lots of fooling around back there by previous owner’s. The headlamps where working then.
Platinum
IMHO, a "short" someplace in the wiring would result in the dreaded Smoke Release. What is more likely is the switch overheated due to high resistance somewhere in the lighting circuit. Better to find and clean/refurb ALL ground points in the light circuit. It wouldn't hurt to add a relay and redundant ground wiring either. A ground wire for the rear is using the license tag fastener inside the car as a ground, that one can be a hidden issue. Lights draw a fairly heavy load compared to most other things, why BMC/Leyland didn't put relays in the lighting run is beyond me.
And don't get me started about aftermarket wiring and controls... :devilgrin:
Mickey Richaud
Grantura_MKI
I have done many plastic English motors and never had all of the issues that folks experience with earths?
All English wiring codes are the same. Really no need for a diagram once you memorize the colours.
C
Crazyman60
C
Crazyman60
I just bought relays from Moss and I am checking wires, and I must say that I am learning the colors of the wiring, the hard way at times.
When I replaced the original headlight switch it was because it had come apart internally. There were were no signs of overheating on the wires or switch itself. The replacement literally melted where the spades are. I will be checking the grounds. Thanks to everyone for your help and insight.
Grantura_MKI
Relays are good as long as they are wired correctly.
They are to take the load away from the switch. Napa sells relays if you need them quicker.
mezy
I've had aftermarket switches in the past. Mostly they are pretty crap compared to an original switch. The parts in as idevthe switch are thinner and contacts are not as good. These arc and Couse the brass bits to heat up and melt the plastic. If you have no alternative use a relay to remove the load from these switches
YakkoWarner
I know Moss sells a relay kit that you can use to take most of the current load away from the switch. There are no lighting relays from the factory, and with all the lamps functioning there is around 15 amps of current going thru that switch (and that can certainly generate enough heat to melt the plastic).
Going to LED bulbs would also reduce the current draw dramatically.
Hangtown Healey Reproduction Shrouds Austin Healey 9
D TR2/3/3A Reproduction TR3A Grille Triumph 63
I Luca P700 reproduction installation Spridgets 7
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
C Recommended reproduction wheels? Austin Healey 29
I Reproduction tachometer drive quality? Spridgets 4
5 4 speed reproduction synchromesh cones Austin Healey 0
G Reproduction A arm question Spridgets 7
angelfj1 Reproduction Lucas Headlamps Triumph 17
W Nice reproduction seat bases Spridgets 0
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
J TR4/4A TR4 reproduction dash pad Triumph 3
sparkydave Darn reproduction parts Spridgets 6
D Reproduction Parts Revisited Triumph 55
angelfj1 Aeroscreen Reproduction Project Triumph 41
D Reproduction Parts Triumph 20
77_MG_Midget MG Midget Reproduction Decals Spridgets 6
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
F TR2/3/3A head light buckets Triumph 3
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
G Brake Light Switch Failure Austin Healey 24
J TR2/3/3A Red ignition light stays on Triumph 7
Chrisc9 TR6 TR6 brake light Triumph 6
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
T Tail light extension Spridgets 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
6 E-Type brake light pressure switch location Jaguar 5
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
R side light install Spridgets 2
S TR6 Oil Pressure Light Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Cappy Ignition Warning Light Austin Healey 6
I TR6 Dash light issues Triumph 19
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
