Replacing the witches nose in-situ. BN1
simon1966
I don't even want to attempt this without some quick guidance. My recently restored 100 has the control head and indicator switch back in the car as it has been since I have owned the car, 30 plus years. It has a later model trafficator switch. Here it is pre-resto.
Is it feasible to replace the switch for a witches nose (which I have in hand) without having to remove the entire control head?
Thanks much
Simon
roscoe
Whitch's nose is the pointy style trafficator lever found in the 100 series cars versus the one he has which I suppose is more like a round clown nose. Someone must have botched a rhinoplasty on his BN1 and bless his heart he wants to make it right.
pan
Sorry mate, but the stator tube will have to be released at the front of the steering box, and pulled through the wheel at least until you can access the screws that attach the control head to the flange at the top of the tube.
Cheers,
Alwyn
simon1966
simon1966
Thanks Alwyn, I had a feeling this was not just a simple pry off the horn button. I think for a while at least, I will be content with keeping my proper nose in a box on the workbench and live with the one installed so many years ago. I am fairly certain that back in the day in the 60's and 70's when my car was nothing but a cheap tatty sports car, that PO's kept it alive by raiding junk yards around Manchester. The non-matching windshield frame parts, the 4 speed box one of the cockpit surround parts all point to the fact that things were simply replaced with used parts rather than fixed. Probably the same for the control head.
simon1966
simon1966
This surgery happened at least 35 years ago and I suspect that the part was not to hand at the time. It is a minor detail, but one that I want to get right, just like the rear reflectors that were wrong and are now correct. They were a lot easier to replace thankfully.
nevets
Steveg
That's a really good repair article. Would the process be much different for a non-adjustable steering wheel? I am considering replacing my repro banjo style wheel with a wood Moto Lita wheel. Thanks.
Editor_Reid
Platinum
I almost hate to say it, but I have seen a few period photos of Hundreds showing the chrome switch/lever as you have. One is from a period full-page ad, so it would not have been retrofitted - it was an ad for a new car.
steveg
Steveg
Can't say for sure, but referring to the Moss catalog section: "Steering Wheels; Control Heads" - the trafficator portion looks the same
simon1966
simon1966
Now that is very interesting Reid. To think that I might be considering replacing an original part of my car does give me pause for thought. You don't happen to have any of these period images to hand do you?
I have just had a quick read of the 2018 Concours guide and it states that a chrome switch like mine was seen on early 100's and that the black pointed beak came along with the non-adjustable steering column. I'll never know for sure, but would not be a shock to discover that my control head assembly came off a junked older car at some point.
Editor_Reid
Platinum
I took a quick stroll through the archives and didn't find one. Fortunately or unfortunately, "the archives" here is a big place and I'll take another look.
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
Joe Reed MGB Replacing heater cables... MG 29
