Replacing the nylon shift lever bushing
jimmyr
On a 100 BN2, can the shift lever bushing on the end of the shift lever be changed from the top without removing the tunnel?
I'm not as well versed with the 3-speed as I am with the 4-speeds (side or center shift) but you can pull out the lever on them with access through the shift boot opening.
Let one of the Hundred guys verify that before you head out to the garage...
roscoe
Yes. All the BN-2s have the 4 speed side shift. Just be careful you don't drop any of the hardware. Remove the boot, remove the nuts and washers on the 3 studs, (there are also special spacers, remove the cup, the fat rubber gasket, the metal plate, and then the thin rubber gasket can stay on if you are withdrawing the lever. The split bushing is held on with a circlip. Be sure the thin rubber gasket goes on first if you take it off. It does make a difference for the engagement of the nylon bushing into the cup on the control lever. I had a very baffling problem a while back, due to mine being assembled incorrectly, causing the bushing to actually pop out of the cup every now and then. Why are you removing the lever, if you don't mind my asking?
J
jimmyr
Thanks for the heads up on replacing the shift bushing; seems straight forward.
I am replacing it as the shift lever is a little sloppy prior to engaging the forks, and the small play I think is the lever bushing. Moss sent me on in brass, and one in nylon, neither had a circlip with them. I hope the old one is still in there.
B
BUNDYRUM
Hello jimmyr,
The side shift gearbox had the brass shift bushing. The nylon one is for center shift boxes.
Best regards,
bundyrum.
Genos2
Actually,both had brass originally. nylon was replacement in early '70s for other British Leyland cars (MGB etc). cheers Genos2
dvu101
So the brass one I just got from Healey Surgeons for a BT7 center shift is right? Right?
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
