Ok. I have the engine raised enough to get the socket on the nut but the impact wrench does not budge the crankshaft nut. It is a right hand thread isn't it?
Thanks
That would fall into the by any means necessary category! I think I would try levering it up with an appropriate-sized screwdriver, keeping the flat-blade parallel to a flat on the nut. If required, you could finish it off with a pair of Channellocks.Thanks for all of the suggestions so far. I pulled the timing chain cover and everything in there looked to be in good shape. (The engine has about 30k miles on it since it was rebuilt 19 years ago.)
I successfully installed the combined damper and pulley that I got from Moss Motors.
Next question: The new damper has a deep recess where for the crankshaft nut. What is the best way to access the locking washer to bend it up to lock the nut?
Thanks,
Peter Schauss
1963 BJ7
I used studs and that allowed me to easily line up the motor mounts with the frame holes. Very easy to do with studs!After more than six weeks of working on the car off and on, I have the car back on the road. As I mentioned in a previous post, the new lock washer barely fit into the recess in the new damper so that there was no way to get any tool on it to bend it up against the nut. I talked to the tech rep from Pro-Race and the Moss technical people and both agreed that if I using blue Loctite and torqueing the nut to 90 ft-lb would be sufficient. I will be checking it regularly.
If I had to do this again I would replace the bolts which hold the motor mounts to the chassis with longer bolts before lifting the engine. When reassembling the car, I spent a number of hours trying to get the holes to line up. Ultimately, I had to remove the carburetors and the heat shield so that I could get the mount on the driver's side bolted down.
Thanks for all of the advice.
