Replacing rear spring eye bushings on a BN1. How difficult?
55modified
Working on suspension. I want to "service" the rear springs by replacing the rubber spring eye bushings on each spring.
Question is: Is it worth the effort? Will they be impossible to get out? Require total removal to get them in a press to seat new bushings?
I did this on my 1954 Willy's Jeep and it made a big difference. My 55' springs look original so I bet they have never been replaced.
steveg
I bought new springs, which included new bushings. I disassembled them and inserted high-pressure teflon tape (a sailing product) between each leaf. This has worked nicely for > 10 years.
Do you still have the original zinc leaves between the springs? It's important for each leaf to slide adjacent to the other leaves - rather than sticking.
Any of this work will require removal of the springs. The hardest part is getting the front pins out. You need to soak them in Kroil or PB blaster. Then if they don't come out, saw them off with a sawzall.
There are many previous threads dealing with spring removal.
Deleted member 19315
I burned out the old rubber to let me drift out the remaining steel sleeve. I made new bushes from nylon and sleeved them inside and out with turned stainless sleeves. Fitted it all up with new pins, drop shackle plates and so forth.I also greased the spring leaves and made and fitted gathers from wetsuit neoprene.
A fair bit of work but worth it I hope.
LarryK
British cars came with leather gathers which were wrapped and tied around the leaf springs and had zerk fitted to keep the springs greased and able to work. Some of the cars, which are 60+ yrs. old I found with the original wraps, still have pretty nice springs, except hardened grease.
LarryK
P.S. Went with what he said so not to confuse.
Sorry big fingers. I made tapered wetsuit rubber sleeves that I pulled over my greased springs. Similar in function to the old type gaiters. Just to keep the grit out.
55modified
55modified
Are BJ8 rear springs same width as BN1? Was thinking about those Prothane poly spring pads if they would fit.
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
R TR2/3/3A Replacing rear springs Triumph 51
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
K TR2/3/3A Replacing rear seal on gearbox? Triumph 10
D Replacing rear leaf springs ? Triumph 6
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
M Tips for replacing Rear Sway Bar Bushings? MG 0
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
vping Need Tips on Replacing Rear Suspension Bushings MG 7
jimbar Replacing rear valance panel Triumph 3
MGretired Replacing rear bearings MG 5
bighly Replacing rear leaf springs Austin Healey 10
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
