A few days ago I started the "Phenolic Spacer" thread as I was preparing to remount the Cold Air Box to my carbs I just rebuilt. I thought I finished the job yesterday until this morning when I pulled the choke cable to start the car and found that when I released the choke the car was running very poorly. On inspection I found that the front choke return spring was not attached to the choke arm and I will have to remove the CAB in order to get the hooked end of the spring into the hole in the arm--another couple of hours to be spent jamming my large hands into a tight space full of sharp edges, etc!
Though the CAB is iconic because of its connection to the M/Le Mans cars it is a major PITA and I have often thought of replacing it with a pair of velocity stacks. Without discussing the merits of the stacks versus a CAB I wonder if it is necessary to install "richer" carb needles to compensate for the alleged increased air flow that the stacks supposedly produce.
Advice/experience will be appreciated.
