This works like a charm every time if you get the right fit. It squirts the old one out and will even give a little smoke, the pressure is incredible. I use a 4 pound hammer, don't be gentle.Billm said:Easiest way to get the old one out is to fill the hole with grease, find a fairly tight fitting dowel and push it into the hole, tap the dowel with a hammer.
The hydraulic force should force the pilot bushing out.
BillM
Spridget64SC said:For the past 20+ years, I've been using a "Cape" chisel shaped tool. Catch the tip in the gap between the crank and the pilot bush and hit with a ballpien hammer. Breaks them right out. Not quite as messy as the grease method.
One word of caution. If you have one of the later 1275's with the thick walled pilot bushing or the needle type bearing, the grease method might be better. Those thick walled (3/4" OD rather than the 5/8") sintered bushings can be stubborn and the steel needle bearings don't fracture like the bushings.
I make a tool to use to install pilot bushes. Uses a 1/2" bolt with the threaded section removed and just enough shank to fit the length of a pilot bush. Slip a 1/2" AN960/SAE washer over the bolt shank and braze both the washer and an old short head stud to the head of the bolt. Makes a handy tool for installing pilot bushings. Gives the pilot bushing something to be "piloted" with.
HTH,
Mike
Any small chisel small eough to give you working room in the ID will work, the idea is o get a couple of groove gong down the sides of the bushing, and it basily crumples and you blow the remaining pieces out, pretty easy. I never had the grease method work for me on MG A or B series engines, and real messy I do this way quite often with the chisel method and it works well. Some of the later 1275 had the roller bearing pilot busihing, now talk about a mother to get out, but the oil lite bronze one is piece of cake, remember to soak the new oil lite bronze pilot in motor oil for bit before installing. Hope this helps.
.Spridget64SC said:"Brainy Buddy" is better than the usual monicker.
Billm said:Good luck finding a pilot bushing remover tool that is that small!
BillM
