I removed the top and bottom screws and removed the cowl that covers the switch internals. When fitting a replacement unit do you have to remove the steering wheel in order to push the wiring thru the column? Also the the unit that is broken has plastic parts inside(probably why it broke?)...the unit I got off Ebay is all metal parts so I'm thinking it must be original unless they made two different types?
