Flatlander
In replacing the seal in the convertible top frame at its attachment to the windshield, I discovered that somewhere in the cars life someone has removed the pop rivets holding the seal channel to the frame and replaced them with small screws. These screws are too long and do not recess sufficiently to allow for the rubber seal to slide onto the channel. In attempting to pop rivet new rivets I am not able to position the pop rivet nozzle flush with the inside of the track such that the rivet head sits up too high. Does anyone know a source where they might sell pop rivet gun nozzles with a longer taper? The nozzle I am using has a small nozzle taper but not sufficient to fit between the legs of the track.
Also has anyone replaced these rivets before and if so what was the approach you used?
Thanks,
Gary
Thanks,
Gary
Hi Guest!
