Hi Guest!
tony barnhill said:Why not just get a good set of used horns....there are plenty of them around.
KLUTZ said:Soldering won't work with the brass body.
PAUL161 said:KLUTZ said:Soldering won't work with the brass body.
<span style="font-weight: bold">A 71 had brass horns?</span> New to me! Could someone explain this? Cast aluminum as far as I know. Also the original horns can be taken apart and rebuilt. I've done it!
KLUTZ said:Thanks Rick.. I sent you a Private correspondence.
Paul
