Replacement Fuel Pump
Obtong
Hello again...my mechanic told me that my carbs couldn't be adjusted too well because my fuel pump is too strong (it was replaced by the previous owner). I've looked at the ones at Moss going from $89 up, but I recently saw an identical looking one in the J. C. Whitney catalog for only $42.
Fuel Pump Web Page
Has anyone had any experience with the non-Moss units. If so, should I get the 2.5 to 4.5 psi (up to 30 gph) or the 1.5 to 3.5 psi (25 gph) unit?
Thanks,
Obtong
I think the 1.5 to 3.5 Psi is the recommended one either way it may be good to have a pressure regulator I have heard that those pumps sre noisey
and I found it cheaper at Advance Auto Parts. Purolater is a facet under a different name. They had the regulator too
Hmm...why would I need a pressure regulator as well? Isn't it OK just to have the fuel pump within the correct pressure range?
Obtong
most of them are generic ranges and the pressure regulator is a good idea,especially with Su carbs. Mine cost less than $10
I'm using the low-pressure Facet pump and Purolator regulator on my street/time trials racer (1500 SPridget). If I turn the regulator up too much, the car floods. I'm running American carburtation....it was even worse with high pressure and SUs. No problems with 1.5 lbs setting....will pull 6000 RPM in 4th gear.
It *is* a noisy devil....even with semi-open 2" side pipe, I can tell it's running.
Note: the Purolator regulator has had a recall (some are prone to fuel leaks due to material problems)! Check your regulator number and "Google" their site address, to see if your's is afffected.
[ 01-20-2003: Message edited by: aeronca65t ]</p>
I fitted a regulator (Schucks, 20 bucks) just before the fuel filter and set it to 2 psi. I'll have to see about getting the carbs adjusted now.
One thing I noticed right away was that my fuel filter now has only a small amount of gas in it, whereas before it was over half full. This is expected, right?
Obtong
That is why I prefer original equipment!! These carbs are set for about 1.5 to 3 lbs pressure!! If you have original, you will never have a problem!! A regulator works too, but you have to know where to set it!!
And you've got to love the click-click-click of the original S.U. fuel pumps . . . It's part of the charm of an MG!
You got to know just where to rap it and just how hard, too!
I ran into the same problem when I swapped back to SU from the PO's Weber. He had a 9# fuel pump feeding the Weber. Gas just poured out the SU's!
The SU pumps are the best. Don't forget that MG has spent many years evolving the car, and the components evolved with the car.
I just replaced the pump on Milou with an electronic SU, and it's GREAT! I had tried to rebuild the old one several times, but I think the diaphragm had stiffened up. I just couldn't get it to tick over reliably.
SUs have the added advantage that when you're about to run out of fuel, your tick*tick*tick turns into a *Brrrrrrrrrrrrr*.
Those darned after-market pumps just never shut up, even when they're up to pressure.
I currently run a weber on my 1500 midget with the stock mechanical fuel pump. I am having fuel starvation problems. Coated tank, inside screen removed, new line, suction filter, discharge filter. Anyway, thinking of going with the Facet type 1.5 - 3 and regulator. Others I've talked too say the loud noise can be quieted if you mount it in a rubber pad. Don't know myself yet,but hope to soon.
